[Qgis-user] plugin installation
Gary Sherman sherman at mrcc.com
Thu Mar 6 17:20:10 PST 2008
On Mar 6, 2008, at 4:11 PM, Martin Dobias wrote:
> On Fri, Mar 7, 2008 at 1:57 AM, Gary Sherman <sherman at mrcc.com> wrote:
>> On Mar 6, 2008, at 11:42 AM, Martin Dobias wrote:
>>> Now I've found out that the problem is due to incorrect creation of
>>> directories - in some cases zip files, directories are not listed
>>> (in
>>> that case we create only top-level dir which leads to the problem
>>> with
>>> subdirectories).
>>> Fixed in trunk in r8191 but users of prebuilt packages will have to
>>> unpack the plugin manually.
>> The version prior to r8191 worked and was not the cause of the issue
>> in this thread. The problem is that the fix has not made it into a
>> released version yet.
> Actually, I had the same error in my fresh svn trunk checkout so I
> doubt that it was working ... were you able to install html_imagemap?
> That .zip file doesn't list the directories, only files. So only the
> top level directory was created which resulted in an error since that
> .zip contains also some more subdirs which were not created.
> Martin
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
-Desktop GIS Book:
   *http://desktopgisbook.com
"We work virtually everywhere"
