[Qgis-user] plugin installation
Gary Sherman sherman at mrcc.com
Thu Mar 6 17:21:46 PST 2008
On Mar 6, 2008, at 4:11 PM, Martin Dobias wrote:
> On Fri, Mar 7, 2008 at 1:57 AM, Gary Sherman <sherman at mrcc.com> wrote:
>> On Mar 6, 2008, at 11:42 AM, Martin Dobias wrote:
>>> Now I've found out that the problem is due to incorrect creation of
>>> directories - in some cases zip files, directories are not listed
>>> (in
>>> that case we create only top-level dir which leads to the problem
>>> with
>>> subdirectories).
>>> Fixed in trunk in r8191 but users of prebuilt packages will have to
>>> unpack the plugin manually.
>> The version prior to r8191 worked and was not the cause of the issue
>> in this thread. The problem is that the fix has not made it into a
>> released version yet.
> Actually, I had the same error in my fresh svn trunk checkout so I
> doubt that it was working ... were you able to install html_imagemap?
> That .zip file doesn't list the directories, only files. So only the
> top level directory was created which resulted in an error since that
> .zip contains also some more subdirs which were not created.
Well then it was just another perturbation that hadn't been accounted
for yet. Hopefully the latest changes will cover all the bases....
-gary
> Martin
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
-Desktop GIS Book:
   *http://desktopgisbook.com
"We work virtually everywhere"
