[Qgis-user] Projections Management Tool
Carson Farmer cfarmer at uvic.ca
Sat Mar 22 12:24:00 PDT 2008
Alessandro,
This is not an error, the first part of the PROJCS["....... string just
gives the name of the projection, and in this case the proj.4 library
does not have a name for this projection I guess. The parameters are
still correct, and when reloading the shapefile, your data should still
project properly. If you look further along the PROJCS["....... string,
you will see that it says: PROJECTION["Transverse_Mercator"], which is
where it defines what projection it is in.
Thanks for testing this out, and I'm glad you found it useful.
Carson
Alessandro Sarretta wrote:
> Hello Carson,
> thankyou for your plugin! It's a very useful tool !
> I'm trying it using QGIS 0.9.2 in WindowsXP. I defined the 3004
> projection for a polygon vector layer. It works fine, but I noticed
> that in the .prj file is written:
> PROJCS["unnamed", ...
> instead of
> PROJCS["Transverse_Mercator", ...
> Is it an error?
> Alessandro Sarretta
> Carson Farmer ha scritto:
>> Hello List,
>> I have developed two projection management tools ( using python )
>> which I would like to disseminate to the general public, but rather
>> than upload directly to the repository ( where people may unwittingly
>> download, use, and then find that it just plain doesn't work ) I
>> though some 'beta' testing might be in order.
>> For anyone who might be interested, the plugin is available from
>> here: http://www.geog.uvic.ca/spar/tools.html
>> The tool basically provides functionality similar to the 'Project',
>> and 'Define Projection' tools in ArcGIS for vector data.  There is a
>> simple description on the website, as well as instructions on how to
>> install/use the plugins.  *You are best off using only the latest
>> version of QGIS.*  I am particularly interested in hearing from any
>> mac users, as I do not have access to a mac for testing myself.
>> Thanks for your help,
>> Sincerely,
>> Carson Farmer
