[Qgis-user] Loading big images in QGIS: Erdas img vs. ecw vs. bigtiff
Carlos Dávila cdavilam at jemila.jazztel.es
Fri Mar 28 08:31:21 PDT 2008
Andreas Neumann escribió:
> Hello,
> I would like to discuss the loading of big images in QGIS: I have an
> aerial image with 56000 x 44000 pixel. I tried three different approaches.
> I wanted to just use one single file instead of tiles. I used gdal to
> prepare the images.
> Here are my results:
> * ECW:
>  - compresses fine
>  - 500mb limit doesn't seem to apply if I use the -co "LARGE_OK=YES"
>  - loads fine and fast with UMN
>  - loads very, very long in QGIS: >4 minutes
>  - once loaded zooming and panning is very quick
On what O.S. are you running qgis? What qgis version? It takes over 10
minutes for me on debian using ecw files between 1-2 GB (tested with
different revisions after 0.9.1 release). Zooming, panning or toggle
vector layers edition takes the same time, not quick as you report. See
bug #778 (https://trac.osgeo.org/qgis/ticket/778) for more info.
> * Erdas imagine (HFA)
>  - spill files don't support compression, spill files have to be used if
> the filesize is bigger than 2GB
>  - loads very fast in QGIS, less than a second
>  - once loaded zooming and panning is slower compared with ecw
> * bigtiff: couldn't get this to work
> So, as a result I would, from a technical point of view, like to go with
> ecw, if the initial, very long loading time could be fixed in QGIS.
> So, here are my questions:
> - will I run into licensing problem with ecw?, esp. if my filesize is
> bigger than 500mb?
> - can the long loading times of the ecw files be fixed in qgis?
> - are there other better alternatives besides ecw/erdas imagine/bigtiff?
> Thank you for discussing this issue.
> Andreas
