[Qgis-user] QGIS and ECW and MrSid formats
Yves Jacolin (free) yjacolin at free.fr
Sat Nov 8 02:56:31 PST 2008
Le samedi 08 novembre 2008, Tim Sutton a écrit :
> Hi Jacolin
> > Camptocamp created such gdal package with ECW. More information here:
> > http://cartoweb.org/cwiki/DebianPackages
> I thought I would give your repo a try on my etch server but I had
> some problems with the pgp key:
> sudo gpg --keyserver subkeys.pgp.net --recv-keys A37E4CF5
> gpg: requesting key A37E4CF5 from hkp server subkeys.pgp.net
> ?: subkeys.pgp.net: Connection refused
> gpgkeys: HTTP fetch error 7: couldn't connect: Connection refused
> gpg: no valid OpenPGP data found.
> gpg: Total number processed: 0
> Also do you have a mrsid library too?
> Thanks!
> Regards
Hi Tim,
This is not my repo, this is the Camptocamp's one ;)
I just tested it and it's work well. Maybe an internet access failed.
gpg: requête de la clé A37E4CF5 du serveur hkp subkeys.pgp.net
gpg: clé A37E4CF5: clé publique « Camptocamp Signing Key
<info at camptocamp.com> » importée
gpg: Quantité totale traitée: 1
gpg:               importée: 1
There's not a MrSID libraray that's I am aware of.
Regads,
Y.
Yves Jacolin
"Donner la liberté aux individus ne suffit pas, il faut aussi leur donner du
pouvoir, de la puissance d'agir." M Gauchet
"Give freedom to people is not enough, we also have to give them the power
to use this freedom, to act". M Gauchet
http://yjacolin.gloobe.org
http://softlibre.gloobe.org
