[Qgis-user] Attribute Actions
Gavin Macaulay gavin at macaulay.co.nz
Mon Nov 24 00:20:56 PST 2008
Gabriele,
Have you looked at the manual for qgis? This includes a section on how to use the Attribute Actions (look in the section on the Vector Properties Dialog). It also gives examples.
Regards
Gavin
---- Original message ----
>Date: Mon, 24 Nov 2008 00:13:00 -0800 (PST)
>From: Gabriele Nolè <gis.gn at libero.it>
>Subject: [Qgis-user] Attribute Actions
>To: qgis-user at lists.osgeo.org
>Hello.
>I read about a presentation that with  Attribute actions I can do:
>1)  Run external programs with feature attributes as arguments
>2)  Write attribute values into a file using the bash:  'bash ­c "echo
>"%fieldname" >>  /home/humarco/attribute.txt" '
>3)  Use %% to insert the attribute where the mouse  points to
>4)   Run actions by righ­clicking into attribute table or identify results
>dialog
>I have not understood (in particular points 2 and 3) and I could not make it
>work.
>Someone may explain the 4 points perhaps with some examples, and so I try
>them?
>Thanks
>Ubuntu 8.10 QGIS 1 preview II
>View this message in context: http://www.nabble.com/Attribute-Actions-tp20639028p20639028.html
>Sent from the qgis-user mailing list archive at Nabble.com.
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
