[Qgis-user] Attribute Actions
Gabriele Nolè
gis.gn at libero.it
Mon Nov 24 03:12:11 PST 2008
Hi Gavin.
Ok, it's true. I found him and now I read.
Gabriele
Gavin Macaulay wrote:
> Gabriele,
> Have you looked at the manual for qgis? This includes a section on how to
> use the Attribute Actions (look in the section on the Vector Properties
> Dialog). It also gives examples.
> Regards
> Gavin
> ---- Original message ----
>>Date: Mon, 24 Nov 2008 00:13:00 -0800 (PST)
>>From: Gabriele Nolè <gis.gn at libero.it>
>>Subject: [Qgis-user] Attribute Actions
>>To: qgis-user at lists.osgeo.org
>>Hello.
>>I read about a presentation that with Attribute actions I can do:
>>1) Run external programs with feature attributes as arguments
>>2) Write attribute values into a file using the bash: 'bash c "echo
>>"%fieldname" >> /home/humarco/attribute.txt" '
>>3) Use %% to insert the attribute where the mouse points to
>>4) Run actions by righclicking into attribute table or identify results
>>dialog
>>I have not understood (in particular points 2 and 3) and I could not make
it
>>work.
>>Someone may explain the 4 points perhaps with some examples, and so I try
>>them?
>>Thanks
>>Ubuntu 8.10 QGIS 1 preview II
>>View this message in context:
http://www.nabble.com/Attribute-Actions-tp20639028p20639028.html
>>Sent from the qgis-user mailing list archive at Nabble.com.
>>_______________________________________________
>>Qgis-user mailing list
>>Qgis-user at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/qgis-user
View this message in context: http://www.nabble.com/Attribute-Actions-tp20639028p20658806.html
