[Qgis-user] qgis 0.11 fails to startup
G. Allegri giohappy at gmail.com
Tue Sep 2 02:39:07 PDT 2008
I didn't post the update yet. The problem is caused by the grass
plugin, because the changes to GRASS in the last SVN releases are
incompatible with the plugin from the repository.
I suppose that the only solution is to compile Qgis. I hope it won't
be so problematic!
2008/9/2 Alex Mandel <tech_dev at wildintellect.com>:
> G. Allegri wrote:
>> I'm using Kubuntu 8.04. I've been able to use QGIS 0.11 from launchpad
>> repositories [1] until two weeks ago. Now it crashes during start-up.
>> It shows the splash box, and begins the loading of the various
>> components but then it crashes. The Python plugins were working fine
>> too...
>> The only changes I've made are to GRASS, as I commpile it by myself,
>> but the two environments are completely indepent as I use the
>> libqgisgrass.0.11 qgis-plugin-grass from the repository.
>> I cannot find traces/log to analyze the error.
>> Hints?
>> Giovanni
>> [1] http://ppa.launchpad.net/qgis/ubuntu hardy main
> What if you launch it from a terminal, do you get any output there?
> Alex
> Qgis-user mailing list
