[Qgis-user] Installer update - more repositories needed! ;)
Micha Silver
Micha at arava.co.il
Wed Sep 10 07:25:41 PDT 2008
Hello Borys:
Today, in a small seminar I was giving using qgis (the first lesson
was to add your new plugin installer) I noticed that on WinXP, a
user with a non-ascii username couldn't install the plugin. The
error showed that the "foreign" characters in the path to .qgis were
not parsed - in the error message the path appeared as "C:\Documents
and Settings\\.qis" which of course is wrong) . On the same
computer, after adding a new user with a simple ascii-only username,
the installer worked fine. Is this something you'd like to address?
Regards,
Micha
>-----Original Message-----
>From: qgis-user-bounces at lists.osgeo.org
>[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Borys
Jurgiel
>Sent: Tuesday, September 09, 2008 3:34 AM
>To: qgis-developer at lists.osgeo.org; qgis-user at lists.osgeo.org
>Subject: [Qgis-user] Installer update - more repositories needed!
>Hi lists,
>I've just updated the Installer in my repo. There are major
>changes below.
>1. It's compatible with both 0.x and 1.x QGIS now.
>2. By default, it uses the main repository. User can click the
>"add 3rd party repositories" button and after accepting
>warning message, he gets more repositories.
>3. The Installer uses DIFFERENT repositories for QGIS 0.x and
>1.x. The alternative solution was to mix old and new plugins
>in one repository and determine the min/max qgis version in
>metadata. I've chosen the former, as it's much more reliable
>and clear I think.
>4. Only repositories compatible with currently used QGIS
>version are used. If one repository has two "instances"
>(containing old-api plugins and new-api plugins), always the
>matching one is choosen by correcting the QSettings. If one
>repository (saved in QSettings) is mismatching and has no
>proper "analog", it's disabled (but automatically enabled
>after publishing the analog). So upgrading from 0.11 to 1.0
>will automatically change the used repository list.
>5. At the moment, our "official" repository is enabled in both
>QGIS 0.x and 1.x, my repository has two instances [1][2],
>while Barry's, Carson's and Paolo's repositories are enabled
>in QGIS 0.x and disabled in 1.x It will be great if every
>repository would be provided in two instances.
>I hope I'm undestandable and Installer's behaviour is clear.
>Regards,
>B.
>PS. I've renamed menu item and window titles from "QGIS Plugin
>Installer"
>to "QGIS Python Plugin Installer". It's related to the earlier
>discussion "Python plugins and C++ plugins: using different terms".
>[1] my repo with new-api plugins:
www.bwj.aster.net.pl/qgis/plugins.xml
>[2] my repo with old-api plugins:
>www.bwj.aster.net.pl/qgis/plugins-oldapi.xml
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
>This mail was received via Mail-SeCure System.
