[Qgis-user] Installer update - more repositories needed! ;)
Paolo Cavallini
cavallini at faunalia.it
Wed Sep 10 07:31:59 PDT 2008
Micha Silver ha scritto:
> Hello Borys:
> Today, in a small seminar I was giving using qgis (the first lesson
> was to add your new plugin installer) I noticed that on WinXP, a
> user with a non-ascii username couldn't install the plugin. The
> error showed that the "foreign" characters in the path to .qgis were
> not parsed - in the error message the path appeared as "C:\Documents
> and Settings\\.qis" which of course is wrong) . On the same
> computer, after adding a new user with a simple ascii-only username,
> the installer worked fine. Is this something you'd like to address?
I confirm, I noticed and reproted this a few months ago, there should be
something in the ML archive.
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
