[Qgis-user] GRASS in QGIS 0.10.0(win)
Malm Paul
paul.malm at saabgroup.com
Thu Sep 25 00:24:48 PDT 2008
Ok,
I've removed the path to the gdal folder (gdal installed by me) and the environment variable.
The I installed QGIS 0.11.0-2, but it is the same. I'm not allowed to select any OGR vector layer, the list button is grayed.
Kind regards,
Paul
From: Marco Pasetti [mailto:marcopstt at gmail.com]
Sent: den 25 september 2008 09:05
To: Malm Paul; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GRASS in QGIS 0.10.0(win)
Paul,
if you want to use GRASS into QGIS you don't need nothing than QGSI itself, that natively comes with GRASS (and all its dependencies) bundled.
a different version of gdal than the one contained in the QGIS release will never work with that version of QGIS
Regards,
Marco
----- Original Message -----
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Sent: Thursday, September 25, 2008 8:36 AM
Subject: [Qgis-user] GRASS in QGIS 0.10.0(win)
I thought I shold try GRASS in QGIS.
First, I have not worked with GRASS and I don't know anything about it.
I created a GRASS mapset in c:\grassdata, a location = newyork and the mapsets PERMANENT and User
I installed GDAL in c:\gdalwin32-1.5
I added c:\gdalwin32-1.5\data to my path
and added the environment variable GDAL_DATA = c:\gdalwin32-1.5\data
I've copied my shape file sets to C:\grassdata\newyork\PERMANENT (I don't know if it is here they should be stored)
Then I tried to import a shapefile with v.in.ogr ,
but I'm not able to select any "OGR vector layer"
Could someone help me, please?
/Paul
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080925/abecceea/attachment.html>
