[Qgis-user] GRASS in QGIS 0.10.0(win)
Marco Pasetti
marcopstt at gmail.com
Thu Sep 25 00:35:37 PDT 2008
Paul,
>I've removed the path to the gdal folder (gdal installed by me) and the
>environment variable.
>The I installed QGIS 0.11.0-2, but it is the same. I'm not allowed to
>select any OGR vector layer, the list button is grayed.
that's because in the current mapset there are no available vector layers
if you simply copied the files from another location, the files may be
corrupted
try to use the sample data downloadable from the qgis installer
Regards,
Marco
