[Qgis-user] GRASS in QGIS 0.10.0(win)
Alex Mandel
tech_dev at wildintellect.com
Thu Sep 25 01:06:04 PDT 2008
Marco Pasetti wrote:
> Paul,
>> I've removed the path to the gdal folder (gdal installed by me) and
>> the environment variable.
>> The I installed QGIS 0.11.0-2, but it is the same. I'm not allowed to
>> select any OGR vector layer, the list button is grayed.
> that's because in the current mapset there are no available vector layers
> if you simply copied the files from another location, the files may be
> corrupted
> try to use the sample data downloadable from the qgis installer
> Regards,
> Marco
When using Grass in QGIS a lot of the operations rely on you having data
loaded in the map first. Try loading a shapefile, and make sure it's
visible. Then use the v.in.ogr
Alex
