[Qgis-user] GRASS in QGIS 0.10.0(win)
Malm Paul paul.malm at saabgroup.com
Thu Sep 25 04:45:45 PDT 2008
Thanks, Alex and Marco!
/Paul
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Alex Mandel
Sent: den 25 september 2008 10:06
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GRASS in QGIS 0.10.0(win)
Marco Pasetti wrote:
> Paul,
>> I've removed the path to the gdal folder (gdal installed by me) and
>> the environment variable.
>> The I installed QGIS 0.11.0-2, but it is the same. I'm not allowed to
>> select any OGR vector layer, the list button is grayed.
> that's because in the current mapset there are no available vector
> layers if you simply copied the files from another location, the files
> may be corrupted try to use the sample data downloadable from the qgis
> installer
> Regards,
> Marco
When using Grass in QGIS a lot of the operations rely on you having data loaded in the map first. Try loading a shapefile, and make sure it's visible. Then use the v.in.ogr
Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
