[Qgis-user] Contour plugin
Giovanni Manghi giovanni.manghi at gmail.com
Mon Aug 3 05:16:31 PDT 2009
On Mon, 2009-08-03 at 12:41 +0200, Lionel Roubeyrie wrote:
> Hi all,
> the last week-end I've made a little qgis plugin to plot contour lines from a
> regular point grid. It's based on matplotlib for contours computation and
> shapely for translating matplotlib resulting arrays to WKT format. I post it on
> the plugin repository and really appreciate feedbacks. In the next weeks I hope
> adding more options (manual levels, quantiles levels, ...) and another plugin
> for filled contours.
> You can have a look here :
> http://youarealegend.blogspot.com/2009/08/contour-plot-for-qgis.html
> Thanks you
thank you for the plugin!
"data field" accepts only integer type columns as it seems?
regards
-- Giovanni --
