[Qgis-user] Contour plugin
Lionel Roubeyrie lroubeyrie at limair.asso.fr
Mon Aug 3 05:32:12 PDT 2009
there's a test on the field typeName, I set it to "integer" and "double".
Giovanni Manghi a écrit :
> On Mon, 2009-08-03 at 12:41 +0200, Lionel Roubeyrie wrote:
>> Hi all,
>> the last week-end I've made a little qgis plugin to plot contour lines from a
>> regular point grid. It's based on matplotlib for contours computation and
>> shapely for translating matplotlib resulting arrays to WKT format. I post it on
>> the plugin repository and really appreciate feedbacks. In the next weeks I hope
>> adding more options (manual levels, quantiles levels, ...) and another plugin
>> for filled contours.
>> You can have a look here :
>> http://youarealegend.blogspot.com/2009/08/contour-plot-for-qgis.html
>> Thanks you
> Hi,
> thank you for the plugin!
> "data field" accepts only integer type columns as it seems?
> regards
> -- Giovanni --
Lionel Roubeyrie - lroubeyrie at limair.asso.fr
Chargé d'études et de maintenance
LIMAIR - la Surveillance de l'Air en Limousin
http://www.limair.asso.fr
