[Qgis-user] Qgis segfaults on Kubuntu
Carson Farmer carson.farmer at gmail.com
Thu Aug 6 15:06:32 PDT 2009
Ricardo,
The solution that Christy Nieman posted may well work as well, but the
root of the problem is likely that one of your qt3 packages isn't
playing nicely with QGIS (and probably other qt applications as well).
The solution:
$ sudo apt-get remove uim-qt3
Let us know if that helps,
Carson
> Carson
> After typing qgis at the konsole I briefly see the splash window
> loading qgis as usual and then it crashes. The only output I get at
> the konsole window is "Segmentation  fault". I can't read the whole
> text that gets diplayed at the splash window, but I can confirm that
> it gets to the "starting python" message (which I think was the last
> message to be displayed usually)
> On Thu, Aug 6, 2009 at 3:52 PM, Carson Farmer<carson.farmer at gmail.com> wrote:
>> Hi Ricardo,
>>> Hello list
>>> Today I upgraded my Kubuntu Jaunty, installing several new packages
>>> (including the shinny kde 4.3). I thought everything went fine, but
>>> now I can't start Qgis. It only gives me a "segmentation fault"
>>> message in the konsole with nothing more.
>> Could you post the konsole output right up to the segfault?
>> Also, what was printed to the qgis splash screen?
>> Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
National University of Ireland, Maynooth,
Email: Carson.Farmer at gmail.com
Web:   http://www.carsonfarmer.com/
       http://www.ftools.ca/
