[Qgis-user] Qgis segfaults on Kubuntu
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Sat Aug 8 09:49:20 PDT 2009
Hi
I don't have the package uim-qt3 installed on my system, so the
problem must lie elsewhere.
Also, the solution Christy posted seems to be for GNOME users, and I'm
on KDE. As I mentioned earlier, Qgis was working fine until I did an
upgrade on some packages... Could it be that it is python related? I
do remember there being some python-kde4 and python-sip packages in
the upgrade. I noticed that I also can't start the eric4 IDE (which is
written in python), but aside from that (and Qgis) I can use my other
software as usual.
No one else having this problem? Help!?
On Thu, Aug 6, 2009 at 11:06 PM, Carson Farmer<carson.farmer at gmail.com> wrote:
> Ricardo,
> The solution that Christy Nieman posted may well work as well, but the root
> of the problem is likely that one of your qt3 packages isn't playing nicely
> with QGIS (and probably other qt applications as well).
> The solution:
> $ sudo apt-get remove uim-qt3
> Let us know if that helps,
> Carson
>> Carson
>> After typing qgis at the konsole I briefly see the splash window
>> loading qgis as usual and then it crashes. The only output I get at
>> the konsole window is "Segmentation  fault". I can't read the whole
>> text that gets diplayed at the splash window, but I can confirm that
>> it gets to the "starting python" message (which I think was the last
>> message to be displayed usually)
>> On Thu, Aug 6, 2009 at 3:52 PM, Carson Farmer<carson.farmer at gmail.com>
>> wrote:
>>> Hi Ricardo,
>>>> Hello list
>>>> Today I upgraded my Kubuntu Jaunty, installing several new packages
>>>> (including the shinny kde 4.3). I thought everything went fine, but
>>>> now I can't start Qgis. It only gives me a "segmentation fault"
>>>> message in the konsole with nothing more.
>>> Could you post the konsole output right up to the segfault?
>>> Also, what was printed to the qgis splash screen?
>>> Carson
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation (NCG),
> National University of Ireland, Maynooth,
> Email: Carson.Farmer at gmail.com
> Web:   http://www.carsonfarmer.com/
>      http://www.ftools.ca/
___________________________ ___ __
Ricardo Garcia Silva
