[Qgis-user] Installing QGIS on CentOS?
Torsten Lange tlange at gwdg.de
Wed Aug 12 02:25:31 PDT 2009
Hi Bruce,
months ago I wanted to install qgis on centos (5.2) and also did not find
adapted packages. The only solution I found was compiling the required things
by myself. This however was smooth and without complications. Ok, the
mentioned system is 32bit, don't know about 64... For most of the dependencies
(e.g. Qt-libs) packages are probably available somewhere. Gdal, geos and proj
would be the compile candidates.
Torsten
Am Mittwoch, 12. August 2009 06:18:06 schrieb Bob Bruce:
> I've developed some python plugins on Windows and wanted to test them on
> Linux before I shared them. My home Linux system is CentOS.
> So I tried installing QGIS via the Fedora RPM and found a long list of
> dependencies that had to be installed first.
> Is there a way to get the whole environment up and running quickly so
> that I can get on with working with QGIS?
> thanks,
>              Bob Bruce
> The output from the RPM run goes like this:
> [root at mappingnerd tmp]# rpm -ivh qgis-1.0.1-1.fc9.x86_64.rpm
> warning: qgis-1.0.1-1.fc9.x86_64.rpm: Header V3 DSA signature: NOKEY,
> key ID ed00d312
> error: Failed dependencies:
>          gpsbabel is needed by qgis-1.0.1-1.fc9.x86_64
>          libICE.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libQtCore.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libQtGui.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libQtNetwork.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libQtSql.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libQtSvg.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libQtXml.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libSM.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libX11.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXcursor.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXext.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXfixes.so.3()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXi.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXinerama.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXrandr.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libXrender.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libc.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libc.so.6(GLIBC_2.2.5)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libc.so.6(GLIBC_2.3.4)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libc.so.6(GLIBC_2.4)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libdl.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libdl.so.2(GLIBC_2.2.5)(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libexpat.so.1()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libfontconfig.so.1()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libfreetype.so.6()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgcc_s.so.1()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgcc_s.so.1(GCC_3.0)(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgdal.so.1()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgeos_c.so.1()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libglib-2.0.so.0()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgsl.so.0()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgslcblas.so.0()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libgthread-2.0.so.0()(64bit) is needed by
> qgis-1.0.1-1.fc9.x86_64 libm.so.6()(64bit) is needed by
>          libm.so.6(GLIBC_2.2.5)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libpng12.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libpq.so.5()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libproj.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libpthread.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libpthread.so.0(GLIBC_2.2.5)(64bit) is needed by
>          librt.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libsqlite3.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libstdc++.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
>          libstdc++.so.6(CXXABI_1.3)(64bit) is needed by
>          libstdc++.so.6(CXXABI_1.3.1)(64bit) is needed by
>          libstdc++.so.6(GLIBCXX_3.4)(64bit) is needed by
>          libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by
>          libz.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
