[Qgis-user] Installing QGIS on CentOS?
Bob Bruce
Bob.Bruce at pobox.com
Tue Aug 11 21:18:06 PDT 2009
I've developed some python plugins on Windows and wanted to test them on
Linux before I shared them. My home Linux system is CentOS.
So I tried installing QGIS via the Fedora RPM and found a long list of
dependencies that had to be installed first.
Is there a way to get the whole environment up and running quickly so
that I can get on with working with QGIS?
thanks,
Bob Bruce
The output from the RPM run goes like this:
[root at mappingnerd tmp]# rpm -ivh qgis-1.0.1-1.fc9.x86_64.rpm
warning: qgis-1.0.1-1.fc9.x86_64.rpm: Header V3 DSA signature: NOKEY,
key ID ed00d312
error: Failed dependencies:
gpsbabel is needed by qgis-1.0.1-1.fc9.x86_64
libICE.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libQtCore.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libQtGui.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libQtNetwork.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libQtSql.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libQtSvg.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libQtXml.so.4()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libSM.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libX11.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXcursor.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXext.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXfixes.so.3()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXi.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXinerama.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXrandr.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libXrender.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libc.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libc.so.6(GLIBC_2.2.5)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libc.so.6(GLIBC_2.3.4)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libc.so.6(GLIBC_2.4)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libdl.so.2()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libdl.so.2(GLIBC_2.2.5)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libexpat.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libfontconfig.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libfreetype.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgcc_s.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgcc_s.so.1(GCC_3.0)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgdal.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgeos_c.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libglib-2.0.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgsl.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgslcblas.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libgthread-2.0.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libm.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libm.so.6(GLIBC_2.2.5)(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libpng12.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libpq.so.5()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libproj.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libpthread.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libpthread.so.0(GLIBC_2.2.5)(64bit) is needed by
librt.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libsqlite3.so.0()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libstdc++.so.6()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
libstdc++.so.6(CXXABI_1.3)(64bit) is needed by
libstdc++.so.6(CXXABI_1.3.1)(64bit) is needed by
libstdc++.so.6(GLIBCXX_3.4)(64bit) is needed by
libstdc++.so.6(GLIBCXX_3.4.9)(64bit) is needed by
libz.so.1()(64bit) is needed by qgis-1.0.1-1.fc9.x86_64
No virus found in this outgoing message.
Checked by AVG - www.avg.com
Version: 8.5.392 / Virus Database: 270.13.50/2296 - Release Date: 08/11/09 06:10:00
