[Qgis-user] Print composer in GGIS 1.0.2 crashes computer unrecoverable
Rainer M Krug r.m.krug at gmail.com
Thu Aug 20 00:29:48 PDT 2009
Hi
I one computer running Hardy Heron (all updates), QGIS 1.0.2, running
against QT 4.4.0 and on another computer against QT 4.4.1
When I create a new project, add a single polygon shapefile with the
size of 25 MB I can crash my whole session so that ONLY remote login
via ssh works to reboot the computer - X is using 100% of the
processor time:
I open the print composer and add the map. Nothing happens for a few
seconds, and trhen the screen goes blank and nothing works any more,
except of the remote login. Interestingly, from the remote login the
speed looks normal and very responsive.
I could reproduce this on both computers. The same happened, after
using Save To Shapefile and using that file.
Can somebody confirm this?
Due to the size (and copyright issues) I can not send around.
Thanks,
Rainer
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
