AW: [Qgis-user] Print composer in GGIS 1.0.2 crashes computerunrecoverable
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Thu Aug 20 00:40:05 PDT 2009
Hi Rainer
Do you have the chance to test it with a current development version (checked out from svn)? If not, could you send me the data privately so that I might test?
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Rainer M Krug
Gesendet: Do 20.08.2009 09:29
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Print composer in GGIS 1.0.2 crashes computerunrecoverable
Hi
I one computer running Hardy Heron (all updates), QGIS 1.0.2, running
against QT 4.4.0 and on another computer against QT 4.4.1
When I create a new project, add a single polygon shapefile with the
size of 25 MB I can crash my whole session so that ONLY remote login
via ssh works to reboot the computer - X is using 100% of the
processor time:
I open the print composer and add the map. Nothing happens for a few
seconds, and trhen the screen goes blank and nothing works any more,
except of the remote login. Interestingly, from the remote login the
speed looks normal and very responsive.
I could reproduce this on both computers. The same happened, after
using Save To Shapefile and using that file.
Can somebody confirm this?
Due to the size (and copyright issues) I can not send around.
Thanks,
Rainer
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
