[Qgis-user] Print composer in GGIS 1.0.2 crashes computerunrecoverable
Rainer M Krug r.m.krug at gmail.com
Thu Aug 20 00:48:44 PDT 2009
I am checking out SVN unstable development trunk:
svn co https://svn.osgeo.org/qgis/trunk/qgis qgis_unstable
I'll compile it and let you know.
Rainer
On Thu, Aug 20, 2009 at 9:40 AM, Hugentobler
Marco<marco.hugentobler at karto.baug.ethz.ch> wrote:
> Hi Rainer
> Do you have the chance to test it with a current development version (checked out from svn)? If not, could you send me the data privately so that I might test?
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Rainer M Krug
> Gesendet: Do 20.08.2009 09:29
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Print composer in GGIS 1.0.2 crashes computerunrecoverable
> Hi
> I one computer running Hardy Heron (all updates), QGIS 1.0.2, running
> against QT 4.4.0 and on another computer against QT 4.4.1
> When I create a new project, add a single polygon shapefile with the
> size of 25 MB I can crash my whole session so that ONLY remote login
> via ssh works to reboot the computer - X is using 100% of the
> processor time:
> I open the print composer and add the map. Nothing happens for a few
> seconds, and trhen the screen goes blank and nothing works any more,
> except of the remote login. Interestingly, from the remote login the
> speed looks normal and very responsive.
> I could reproduce this on both computers. The same happened, after
> using Save To Shapefile and using that file.
> Can somebody confirm this?
> Due to the size (and copyright issues) I can not send around.
> Thanks,
> Rainer
> Rainer M. Krug, Centre of Excellence for Invasion Biology,
> Stellenbosch University, South Africa
> Qgis-user mailing list
