[Qgis-user] 1.1.0 Unstable - not a valid or recognized raster data source
swapnil appa chaudhary sslan at rediffmail.com
Sun Aug 23 22:46:42 PDT 2009
Hi Darren,
This problem exist with the standalone version of QGIS Kore and QGIS Pan, both.
This issue has been already discussed for Win Vista and Win XP separately in QGIS forum. Have a look at the following links,
http://forum.qgis.org/viewtopic.php?f=2&t=4761
http://forum.qgis.org/viewtopic.php?f=2&t=4660
It seems can be solved by installing OSGeo installer than standalone. I've tried it and it does work. Well, it ain't the right way though. Raster and vector layers should open in GRASS plugin thr the QGIS. Lets hope it will get fixed in next stable version.
Best,
Swapnil
On Sun, 23 Aug 2009 19:26:55 +0530 wrote
>Can anyone have a look to see if this is just me? QGIS can't read GRASS
rasters:
OS = Windows vista,
Installed via standalone (internet connection is poor so this is the
only option for me)
GRASS 6.4 -
http://grass.itc.it/grass64/binary/mswindows/native/WinGRASS-6.4.0SVN-r38537-1-Setup.exe
QGIS 1.1.0 - http://download.osgeo.org/qgis/win32/QGIS-1.1.0-0-Setup.exe
When I start, QGIS can't find GRASS (GISBASE), so I manually point it to
"C:\Program Files\QuantumGIS\grass".
Try to load a GRASS raster and now "C:/Users/Darren/Documents/GIS
DataBase/test/PERMANENT/cellhd/comp543" is not a valid or recognized
raster data source".
I had the same issue with QGIS 1.0.2-Kore. Uninstalled QGIS (via control
panel - remove programs) and then installed 1.1.0......
So far everything else seems to be fine (projects open fine, GPS plugin
etc). Any suggestions?
Many thanks,
Darren
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090824/ddb46c23/attachment.html>
