[Qgis-user] Add Raster Layer Restricted to Types of GRASS Layer and is Not a Supported Raster Data Source
Bob Bruce Bob.Bruce at pobox.com
Mon Aug 24 07:11:09 PDT 2009
Thanks for getting back to me, Peter. You gave me some idea of where to
look although I couldn't find the GDAL_SKIP environment variable being
set anywhere.
I looked through all of the .bat files that were run as QGIS started up
and noticed that I had this call "call "%OSGEO4W_ROOT%"\bin\gdal16.bat"
in my QGIS-1.1.bat file even though GDAL.bat was called indirectly in
this call: "call "%OSGEO4W_ROOT%"\bin\o4w_env.bat".
So I just REMed out the call to gdal16.bat in the QGIS-1.1.bat file and
got my list of raster data types back.
thanks again,
                     Bob Bruce
On 8/24/2009 8:27 AM, Peter Ersts wrote:
> Bob,
> The file list in the open raster dialog is dynamically built each time
> QGIS starts by getting a list of supported formats from GDAL.
> Have you ever set the GDAL_SKIP environment variable? If it is set try
> removing it.
> -pete
> Bob Bruce wrote:
>> I'm hoping that someone can help....
>> I just installed versions (1.0, 1.2, and 1.1) of QGIS using the
>> OSGEO4W installer. I first ran 1.2 and added 4 .tif files to a new
>> QGIS project file and saved it. I shut down QGIS and later re-opened
>> it and tried opening the project and got messages saying that the
>> layers couldn't be found. When I tried adding the .tif files again
>> the dialog for adding image layers only displayed the type "GRASS and
>> all other files", this was different from what it showed originally.
>> When I tried selecting an image using this type I got the error
>> message that: "this is not a supported raster data source". I tried
>> uninstalling everything that was installed (using the OSGEO4W
>> installer) and then reinstalling everything but this did not help. I
>> had the QGIS versions and GRASS desktop applications installed and
>> several libraries and command line utilities installed.
>> Is there a way to get back the full list of raster data types to the
>> dialog to add the raster layers?
>> thanks,
>>             Bob Bruce
>> No virus found in this outgoing message.
>> Checked by AVG - www.avg.com Version: 8.5.392 / Virus Database:
>> 270.13.65/2322 - Release Date: 08/23/09 18:03:00
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Version: 8.5.392 / Virus Database: 270.13.65/2323 - Release Date: 08/24/09 06:05:00
