[Qgis-user] Re: manageR question - "'QXmlStreamReader' is not defined" error
Carson Farmer
carson.farmer at gmail.com
Mon Aug 24 07:41:20 PDT 2009
Hi Rainer,
> Hi
> I tried to use manageR again, but I get that dreaded
> "'QXmlStreamReader' is not defined" error (see below). This was raised
> already a few times, but I did niot find a fix. Is there any progress?
There is progress yes... I have removed it as a dependency in the newer
version of manageR. This newer version will be totally reworked, and
will be released in the next few weeks (probably). Unfortunately, it
still needs work, so I won't be able to release it right away. In the
mean time, try changing line 8 of your 'config.ini' file from
'auto_completion: commands.xml' to 'auto_completion: None'. This file is
located in your manageR folder:
/home/username/.qgis/python/plugins/manageR. You won't have
autocompletion enabled, but if you can live without that for a while,
you'll be able to use manageR without problems (hopefully ;-p).
Cheers,
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
National University of Ireland, Maynooth,
Email: Carson.Farmer at gmail.com
Web: http://www.carsonfarmer.com/
http://www.ftools.ca/
