[Qgis-user] Re: manageR question - "'QXmlStreamReader' is not defined" error
Rainer M Krug
r.m.krug at gmail.com
Mon Aug 24 08:46:06 PDT 2009
On Mon, Aug 24, 2009 at 4:41 PM, Carson Farmer<carson.farmer at gmail.com> wrote:
> Hi Rainer,
>> Hi
>> I tried to use manageR again, but I get that dreaded
>> "'QXmlStreamReader' is not defined" error (see below). This was raised
>> already a few times, but I did niot find a fix. Is there any progress?
> There is progress yes... I have removed it as a dependency in the newer
> version of manageR. This newer version will be totally reworked, and will be
> released in the next few weeks (probably). Unfortunately, it still needs
> work, so I won't be able to release it right away. In the mean time, try
> changing line 8 of your 'config.ini' file from 'auto_completion:
> commands.xml' to 'auto_completion: None'. This file is located in your
> manageR folder:
> /home/username/.qgis/python/plugins/manageR. You won't have autocompletion
> enabled, but if you can live without that for a while, you'll be able to use
> manageR without problems (hopefully ;-p).
Thanks Carson
I am looking forward to the new version. The modification in the ini
file improved it - I can start manageR - but as soon as I type
anything, I get the following error:
An error has occured while executing Python code:
File "/home/rkrug/.qgis//python/plugins/manageR/QConsole.py", line
142, in keyPressEvent
if not self.isCursorInEditionZone():
385, in isCursorInEditionZone
block = self.document().lastBlock()
AttributeError: lastBlock
Python version:
2.5.2 (r252:60911, Jul 22 2009, 15:52:25)
[GCC 4.2.4 (Ubuntu 4.2.4-1ubuntu3)]
Python path:['/usr/share/qgis/python',
'/home/rkrug/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python25.zip', '/usr/lib/python2.5',
'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
'/usr/lib/python2.5/lib-dynload',
'/usr/local/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages/Numeric',
'/usr/lib/python2.5/site-packages/PIL',
'/usr/lib/python2.5/site-packages/gst-0.10',
'/var/lib/python-support/python2.5',
'/usr/lib/python2.5/site-packages/gtk-2.0',
'/var/lib/python-support/python2.5/gtk-2.0',
'/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode',
'/home/rkrug/.qgis/python/plugins/fTools/tools']
Cheers
Rainer
> Cheers,
> Carson
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation (NCG),
> National University of Ireland, Maynooth,
> Email: Carson.Farmer at gmail.com
> Web: http://www.carsonfarmer.com/
> http://www.ftools.ca/
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
