[Qgis-user] Re: manageR question - "'QXmlStreamReader' is not defined" error
Carson Farmer
carson.farmer at gmail.com
Tue Aug 25 05:11:45 PDT 2009
hmmm, this must be a function that was added with Qt4.5... sorry about that!
I'll try to implement this without that function...
you may consider upgrading to Qt4.5, as I suspect this is also why you were
having trouble with the xml reader as well...
I will let you know where I get with this asap.
Carson
On Mon, Aug 24, 2009 at 4:46 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> On Mon, Aug 24, 2009 at 4:41 PM, Carson Farmer<carson.farmer at gmail.com>
> wrote:
> > Hi Rainer,
> >> Hi
> >> I tried to use manageR again, but I get that dreaded
> >> "'QXmlStreamReader' is not defined" error (see below). This was raised
> >> already a few times, but I did niot find a fix. Is there any progress?
> > There is progress yes... I have removed it as a dependency in the newer
> > version of manageR. This newer version will be totally reworked, and will
> be
> > released in the next few weeks (probably). Unfortunately, it still needs
> > work, so I won't be able to release it right away. In the mean time, try
> > changing line 8 of your 'config.ini' file from 'auto_completion:
> > commands.xml' to 'auto_completion: None'. This file is located in your
> > manageR folder:
> > /home/username/.qgis/python/plugins/manageR. You won't have
> autocompletion
> > enabled, but if you can live without that for a while, you'll be able to
> use
> > manageR without problems (hopefully ;-p).
> Thanks Carson
> I am looking forward to the new version. The modification in the ini
> file improved it - I can start manageR - but as soon as I type
> anything, I get the following error:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/rkrug/.qgis//python/plugins/manageR/QConsole.py", line
> 142, in keyPressEvent
> if not self.isCursorInEditionZone():
> 385, in isCursorInEditionZone
> block = self.document().lastBlock()
> AttributeError: lastBlock
> Python version:
> 2.5.2 (r252:60911, Jul 22 2009, 15:52:25)
> [GCC 4.2.4 (Ubuntu 4.2.4-1ubuntu3)]
> Python path:['/usr/share/qgis/python',
> '/home/rkrug/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python25.zip', '/usr/lib/python2.5',
> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
> '/usr/lib/python2.5/lib-dynload',
> '/usr/local/lib/python2.5/site-packages',
> '/usr/lib/python2.5/site-packages',
> '/usr/lib/python2.5/site-packages/Numeric',
> '/usr/lib/python2.5/site-packages/PIL',
> '/usr/lib/python2.5/site-packages/gst-0.10',
> '/var/lib/python-support/python2.5',
> '/usr/lib/python2.5/site-packages/gtk-2.0',
> '/var/lib/python-support/python2.5/gtk-2.0',
> '/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode',
> '/home/rkrug/.qgis/python/plugins/fTools/tools']
> Cheers
> Rainer
> > Cheers,
> > Carson
> > Carson J. Q. Farmer
> > ISSP Doctoral Fellow
> > National Centre for Geocomputation (NCG),
> > National University of Ireland, Maynooth,
> > Email: Carson.Farmer at gmail.com
> > Web: http://www.carsonfarmer.com/
> > http://www.ftools.ca/
> Rainer M. Krug, Centre of Excellence for Invasion Biology,
> Stellenbosch University, South Africa
Carson Farmer
John Hume Building,
Maynooth,
Co. Kildare,
Ireland.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090825/d4afa782/attachment.html>
