[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Goyo goyodiaz at gmail.com
Fri Aug 28 08:03:04 PDT 2009
I had the same problem and then I realized that I had activated a bunch
of repositories with QGis and GRASS packages. So I uninstalled QGis,
deactivated all that repos but Ubuntugis, apt-get update and installed
again. That fixed the issue.
Goyo
El vie, 28-08-2009 a las 12:39 +0200, Agustin Lobo escribió:
> Hi!
> After upgrading to qgis 1.2.01~jaunty, qgis does not start.
> If I run qgis from a terminal, I get:
> /usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
> I've tried
> ~$ sudo apt-get install libqgis
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> E: Couldn't find package libqgis
> I've reinstalled libqgis1.2.0_1.2.0-1~jaunty1_i386.deb
> <https://launchpad.net/%7Eubuntugis/+archive/ubuntugis-unstable/+files/libqgis1.2.0_1.2.0-1%7Ejaunty1_i386.deb>
> from
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
> but still have the same problem
> Is this a problem with the package or am I doing something wrong?
> Thanks for any advice
> Agus
> Qgis-user mailing list
