[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Agustin Lobo
alobolistas at gmail.com
Fri Aug 28 09:45:54 PDT 2009
Are you using qgis 1.2.01 on ubuntu jaunty? Are you using the grass plugin?
If yes, could you check if you have libgdal1-1.5.0-grass and/or
libgdal1-1.6.0-grass ?
I think that the problem is there because:
1. If I install qgis 1.2.01 having the
http://ppa.launchpad.net/qgis/unstable/ubuntu
as the repository (and not http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu)
I get the same problem as stated in my previous message.
I've realized that the grass plugin installs
despite the fact that I do have
2. If I uninstal the grass plugin but keep both libgdal1-1.*, I can
start qgis
but get the following messages in the console:
~$ qgis
ERROR 1: libgrass_I.so: cannot open shared object file: No such file or
directory
directory
Python support ENABLED :-)
Loaded : fTools (package: fTools)
directory
directory
/usr/lib/python2.6/dist-packages/osgeo/gdal.py:81: DeprecationWarning:
gdal.py was placed in a namespace, it is now available as osgeo.gdal
DeprecationWarning)
etc
3. If I remove libgdal1-1.5.0-grass, qgis starts up and I just get the
following in the console:
DeprecationWarning)
The problem is that I do need the grass plugin now. I suspect that
removing libgdal1-1.6.0-grass
would let me install the grass plugin with no problems, but I'm using
libgdal1-1.6.0-grass for
ecw support...
Agus
Goyo wrote:
> I had the same problem and then I realized that I had activated a bunch
> of repositories with QGis and GRASS packages. So I uninstalled QGis,
> deactivated all that repos but Ubuntugis, apt-get update and installed
> again. That fixed the issue.
> Goyo
> El vie, 28-08-2009 a las 12:39 +0200, Agustin Lobo escribió:
>> Hi!
>> After upgrading to qgis 1.2.01~jaunty, qgis does not start.
>> If I run qgis from a terminal, I get:
>> /usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
>> I've tried
>> ~$ sudo apt-get install libqgis
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> E: Couldn't find package libqgis
>> I've reinstalled libqgis1.2.0_1.2.0-1~jaunty1_i386.deb
>> <https://launchpad.net/%7Eubuntugis/+archive/ubuntugis-unstable/+files/libqgis1.2.0_1.2.0-1%7Ejaunty1_i386.deb>
>> from
>> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
>> but still have the same problem
>> Is this a problem with the package or am I doing something wrong?
>> Thanks for any advice
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090828/4fd1fd21/attachment.vcf>
