[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Goyo goyodiaz at gmail.com
Sat Aug 29 00:54:26 PDT 2009
El vie, 28-08-2009 a las 18:45 +0200, Agustin Lobo escribió:
> Are you using qgis 1.2.01 on ubuntu jaunty? Are you using the grass plugin?
Mmmm... I don't know what happened but now I get a segfault when I
launch qgis (1.2.0-1~jaunty1). It worked a few days ago in Jaunty 64
bits, after uninstall - deactivate repos - install.
> If yes, could you check if you have libgdal1-1.5.0-grass and/or
> libgdal1-1.6.0-grass ?
These packages were installed with qgis:
libgdal1-1.5.0 (1.5.2-3ubuntu1)
libgdal1-1.5.0-grass (1.5.2-1)
libgdal1-1.6.0 (1.6.1-1~jaunty2)
Also I have this available but not installed:
libgdal1-1.6.0-grass (1.6.0-2)
It seems weird to me that both 1.5 and 1.6 versions of libgdal are
required.
As I said I only have activated the ubuntugis-unstable repo and things
are broken now. I will try others if I find the time.
> I think that the problem is there because:
> 1. If I install qgis 1.2.01 having the
> http://ppa.launchpad.net/qgis/unstable/ubuntu
> as the repository (and not http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu)
> I get the same problem as stated in my previous message.
> I've realized that the grass plugin installs
> despite the fact that I do have
> 2. If I uninstal the grass plugin but keep both libgdal1-1.*, I can
> start qgis
> but get the following messages in the console:
> ~$ qgis
> ERROR 1: libgrass_I.so: cannot open shared object file: No such file or
> directory
> directory
> Python support ENABLED :-)
> Loaded : fTools (package: fTools)
> directory
> directory
> /usr/lib/python2.6/dist-packages/osgeo/gdal.py:81: DeprecationWarning:
> gdal.py was placed in a namespace, it is now available as osgeo.gdal
>   DeprecationWarning)
> etc
> 3. If I remove libgdal1-1.5.0-grass, qgis starts up and I just get the
> following in the console:
>   DeprecationWarning)
> The problem is that I do need the grass plugin now. I suspect that
> removing libgdal1-1.6.0-grass
> would let me install the grass plugin with no problems, but I'm using
> libgdal1-1.6.0-grass for
> ecw support...
> Agus
> Goyo wrote:
> > I had the same problem and then I realized that I had activated a bunch
> > of repositories with QGis and GRASS packages. So I uninstalled QGis,
> > deactivated all that repos but Ubuntugis, apt-get update and installed
> > again. That fixed the issue.
> > Goyo
> > El vie, 28-08-2009 a las 12:39 +0200, Agustin Lobo escribió:
> >> Hi!
> >> After upgrading to qgis 1.2.01~jaunty, qgis does not start.
> >> If I run qgis from a terminal, I get:
> >> /usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
> >> I've tried
> >> ~$ sudo apt-get install libqgis
> >> Reading package lists... Done
> >> Building dependency tree
> >> Reading state information... Done
> >> E: Couldn't find package libqgis
> >> I've reinstalled libqgis1.2.0_1.2.0-1~jaunty1_i386.deb
> >> <https://launchpad.net/%7Eubuntugis/+archive/ubuntugis-unstable/+files/libqgis1.2.0_1.2.0-1%7Ejaunty1_i386.deb>
> >> from
> >> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
> >> but still have the same problem
> >> Is this a problem with the package or am I doing something wrong?
> >> Thanks for any advice
> >> Agus
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
