[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Goyo goyodiaz at gmail.com
Sat Aug 29 07:40:59 PDT 2009
El sáb, 29-08-2009 a las 14:36 +0200, Jürgen E. Fischer escribió:
> Hi Goyo,
> On Sat, 29. Aug 2009 at 12:06:24 +0200, Goyo wrote:
> > Packages in ubuntugis-unstable[2] are working for me, even after with
> > libgdal1-1.6.0-grass installed. Packages in
> > qgis-unstable-ubuntugis-jef[3] cause the symbol lookup error, even if
> > they have the same version number.
> qgis-unstable-ubuntugis-jef is just for test builds.  After the builds
> succeeded they were copied to unstable-ubuntugis.
My mistake. The packages causing the error were from qgis-unstable-jef
(did not tried qgis-unstable). After adding it to my sources without
removing ubuntugis-unstable i get some updates
libqgis1.2.0 (1.2.0-1~jaunty1) to 1.2.0-1~jaunty1
qgis (1.2.0-1~jaunty1) to 1.2.0-1~jaunty1
qgis-plugin-grass (1.2.0-1~jaunty1) to 1.2.0-1~jaunty1
qgis-plugin-grass-common (1.2.0-1~jaunty1) to 1.2.0-1~jaunty1
and then the symbol lookup error comes back.
Of course I have no particular reason for using both ubuntugis-unstable
and qgis-unstable(-jef?). I just like to mess things up.
Goyo
> So it's virtually impossible that the packages in unstable-ubuntugis work any
> different than those from qgis-unstable-ubuntugis-jef. They are the same.
> You probably didn't consider that the qgis-unstable-ubuntugis-jef repository
> depends on unstable-ubuntugis.   So you need the latter in any case.   And as
> it already contains the packages from qgis-unstable-ubuntugis-jef, you don't
> need my test repository at all.
> But just using qgis-unstable-ubuntugis-jef will probably give you the right
> qgis, but some older dependencies from plain ubuntu - looks like that doesn't
> work.  But that was never intended anyway.
> If you don't want ubuntugis the qgis unstable ppa[1] has packages that work
> with plain ubuntu.
> hth
> Jürgen
> [1] https://launchpad.net/~qgis/+archive/unstable
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
