[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Agustin Lobo alobolistas at gmail.com
Sun Aug 30 00:03:58 PDT 2009
Jürgen,
But going back to my original question, and having only
 http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
as repository, qgis does not start if the grass plugin is installed.
Note that the grass plugin requires
libgdal1-1.5.0-grass
despite the fact that I do have
libgdal1-1.6.0-grass
Could this be the reason for the crash?
/usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
Should I remove  libgdal1-1.6.0-grass ? The problem is
that I need it for ecw support, don't I? Is
libgdal1-1.6.0-grass being avoided for the grass plugin because it's still
on ubuntugis-unstable?
Agus
Jürgen E. Fischer wrote:
> Hi Goyo,
> On Sat, 29. Aug 2009 at 12:06:24 +0200, Goyo wrote:
>> Packages in ubuntugis-unstable[2] are working for me, even after with
>> libgdal1-1.6.0-grass installed. Packages in
>> qgis-unstable-ubuntugis-jef[3] cause the symbol lookup error, even if
>> they have the same version number.
> qgis-unstable-ubuntugis-jef is just for test builds.  After the builds
> succeeded they were copied to unstable-ubuntugis.
> So it's virtually impossible that the packages in unstable-ubuntugis work any
> different than those from qgis-unstable-ubuntugis-jef. They are the same.
> You probably didn't consider that the qgis-unstable-ubuntugis-jef repository
> depends on unstable-ubuntugis.   So you need the latter in any case.   And as
> it already contains the packages from qgis-unstable-ubuntugis-jef, you don't
> need my test repository at all.
> But just using qgis-unstable-ubuntugis-jef will probably give you the right
> qgis, but some older dependencies from plain ubuntu - looks like that doesn't
> work.  But that was never intended anyway.
> If you don't want ubuntugis the qgis unstable ppa[1] has packages that work
> with plain ubuntu.
> hth
> Jürgen
> [1] https://launchpad.net/~qgis/+archive/unstable
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090830/5c2a1203/attachment.vcf>
