[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Goyo goyodiaz at gmail.com
Sun Aug 30 02:10:14 PDT 2009
El dom, 30-08-2009 a las 09:03 +0200, Agustin Lobo escribió:
> Jürgen,
> But going back to my original question, and having only
>  http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
> as repository, qgis does not start if the grass plugin is installed.
> Note that the grass plugin requires
> libgdal1-1.5.0-grass
> despite the fact that I do have
> libgdal1-1.6.0-grass
> Could this be the reason for the crash?
> /usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
> Should I remove  libgdal1-1.6.0-grass ? The problem is
> that I need it for ecw support, don't I? Is
> libgdal1-1.6.0-grass being avoided for the grass plugin because it's still
> on ubuntugis-unstable?
> Agus
Agus, did tou try ubuntugis-unstable instead of qgis-unstable? As I said
it works for me with both versions of libgdal1-1.?.0-grass installed,
althouh I did not try ecw.
Goyo
> Jürgen E. Fischer wrote:
> > Hi Goyo,
> > On Sat, 29. Aug 2009 at 12:06:24 +0200, Goyo wrote:
> >> Packages in ubuntugis-unstable[2] are working for me, even after with
> >> libgdal1-1.6.0-grass installed. Packages in
> >> qgis-unstable-ubuntugis-jef[3] cause the symbol lookup error, even if
> >> they have the same version number.
> > qgis-unstable-ubuntugis-jef is just for test builds.  After the builds
> > succeeded they were copied to unstable-ubuntugis.
> > So it's virtually impossible that the packages in unstable-ubuntugis work any
> > different than those from qgis-unstable-ubuntugis-jef. They are the same.
> > You probably didn't consider that the qgis-unstable-ubuntugis-jef repository
> > depends on unstable-ubuntugis.   So you need the latter in any case.   And as
> > it already contains the packages from qgis-unstable-ubuntugis-jef, you don't
> > need my test repository at all.
> > But just using qgis-unstable-ubuntugis-jef will probably give you the right
> > qgis, but some older dependencies from plain ubuntu - looks like that doesn't
> > work.  But that was never intended anyway.
> > If you don't want ubuntugis the qgis unstable ppa[1] has packages that work
> > with plain ubuntu.
> > hth
> > Jürgen
> > [1] https://launchpad.net/~qgis/+archive/unstable
> Qgis-user mailing list
