[Qgis-user] symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Agustin Lobo alobolistas at gmail.com
Sun Aug 30 03:27:54 PDT 2009
Confirmed:
If qgis 1.2.0.1 (including the grass plugin) is installed from the
repository indicated in the qgis download page:
 http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
qgis crashes at startup with:
/usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
Installing using
http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
as repository works fine.
Also, Synaptic does not list libqgis.* when qgis is used in the Search field
(you must write libqgis to see libqgis* items listed) and
does not select libqgis* for removal when qgis is selected for removal (even complete removal). As a matter of fact, I had both libqgis.1.1.0 and libqgis1.2.0, although this duplicity
does not seem to have been a problem.
Thanks
Agus
Goyo wrote:
> El dom, 30-08-2009 a las 09:03 +0200, Agustin Lobo escribió:
>> Jürgen,
>> But going back to my original question, and having only
>> as repository, qgis does not start if the grass plugin is installed.
>> Note that the grass plugin requires
>> libgdal1-1.5.0-grass
>> despite the fact that I do have
>> libgdal1-1.6.0-grass
>> Could this be the reason for the crash?
>> Should I remove  libgdal1-1.6.0-grass ? The problem is
>> that I need it for ecw support, don't I? Is
>> libgdal1-1.6.0-grass being avoided for the grass plugin because it's still
>> on ubuntugis-unstable?
>> Agus
> Agus, did tou try ubuntugis-unstable instead of qgis-unstable? As I said
> it works for me with both versions of libgdal1-1.?.0-grass installed,
> althouh I did not try ecw.
> Goyo
>> Jürgen E. Fischer wrote:
>>> Hi Goyo,
>>> On Sat, 29. Aug 2009 at 12:06:24 +0200, Goyo wrote:
>>>> Packages in ubuntugis-unstable[2] are working for me, even after with
>>>> libgdal1-1.6.0-grass installed. Packages in
>>>> qgis-unstable-ubuntugis-jef[3] cause the symbol lookup error, even if
>>>> they have the same version number.
>>> qgis-unstable-ubuntugis-jef is just for test builds.  After the builds
>>> succeeded they were copied to unstable-ubuntugis.
>>> So it's virtually impossible that the packages in unstable-ubuntugis work any
>>> different than those from qgis-unstable-ubuntugis-jef. They are the same.
>>> You probably didn't consider that the qgis-unstable-ubuntugis-jef repository
>>> depends on unstable-ubuntugis.   So you need the latter in any case.   And as
>>> it already contains the packages from qgis-unstable-ubuntugis-jef, you don't
>>> need my test repository at all.
>>> But just using qgis-unstable-ubuntugis-jef will probably give you the right
>>> qgis, but some older dependencies from plain ubuntu - looks like that doesn't
>>> work.  But that was never intended anyway.
>>> If you don't want ubuntugis the qgis unstable ppa[1] has packages that work
>>> with plain ubuntu.
>>> hth
>>> Jürgen
>>> [1] https://launchpad.net/~qgis/+archive/unstable
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090830/eff8dab6/attachment.vcf>
