[Qgis-user] Projection
Giovanni Manghi giovanni.manghi at gmail.com
Mon Aug 31 11:26:07 PDT 2009
did you checked
"enable on the fly CRS transformation" in the properties of your
project?
-- Giovanni --
On Mon, 2009-08-31 at 20:16 +0200, Sarel Coetzer wrote:
> Hi
> Has anyone had to re-project layer files with different projections in
> Quantum 1.0.2 ?
> I have two layers,
> 1 - Geographic projected layer (WGS84) and an
> 2 - Unknown layer (meters is visible) so need to project to
> WGS/UTM-36S
> After loading the two layers it was expected not to overlay. I changed
> the CRS of the unknown projection layer to WGS/UTM-36S. Nothing
> happened , the layer still does not overlay. I had to save the layer
> file with the new CRS and restart the application, reload the new
> layer (new CRS) with the geographic project layer to achieve the
> require result.
> Is this standard operating procedures or should the layers "refresh"
> in the same session after altering the CRS?
> Regards
> Sarel
> http://sarelgis.blogspot.com/
> Qgis-user mailing list
