[Qgis-user] Projection
Sarel Coetzer geotech.sarel at gmail.com
Mon Aug 31 11:56:25 PDT 2009
Hi Giovanni
Yes I have tried the OTF facility and still the layers wont overlay. The
issue is that changes can be made to the CRS but it does not take effect
until the layer file is saved with the new CRS values and is required to be
reloaded in a new session. Surely the layers should refresh with the newly
selected CRS and display in the correct location unless I am missing
something fundamentally.
Regards
Sarel
On Mon, Aug 31, 2009 at 8:26 PM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> Hi,
> did you checked
> "enable on the fly CRS transformation" in the properties of your
> project?
> -- Giovanni --
> On Mon, 2009-08-31 at 20:16 +0200, Sarel Coetzer wrote:
> > Hi
> > Has anyone had to re-project layer files with different projections in
> > Quantum 1.0.2 ?
> > I have two layers,
> > 1 - Geographic projected layer (WGS84) and an
> > 2 - Unknown layer (meters is visible) so need to project to
> > WGS/UTM-36S
> > After loading the two layers it was expected not to overlay. I changed
> > the CRS of the unknown projection layer to WGS/UTM-36S. Nothing
> > happened , the layer still does not overlay. I had to save the layer
> > file with the new CRS and restart the application, reload the new
> > layer (new CRS) with the geographic project layer to achieve the
> > require result.
> > Is this standard operating procedures or should the layers "refresh"
> > in the same session after altering the CRS?
> > Regards
> > Sarel
> > http://sarelgis.blogspot.com/
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090831/a1e63388/attachment.html>
