Re: FW: [Qgis-user] DEM matching to points - how to load plugins in windows
Swapnil Chaudhari sslan at rediffmail.com
Thu Dec 3 06:11:25 PST 2009
Hi Dodd
It is a bit tricky to do the manual installation of plugins. There are some issues which I've faced if there are any old versions available and you are trying to load it again over newer versions. I would suggest you to get the fetch python plug-in insted of manual method.
For doing so few things you have to check,
1. See if your proxies are set properly.
----- setting----options----and proxy in the option box.
2. This plug-in that you are interested in is available in Borys Jurgiel's Repository
http://bwj.aster.net.pl/qgis/plugins.xml
so kindly make sure you add it thr add 3rd part repository option.
It should be connected to the repository if everything is fine.
Kindly write back if it doesn't work.
Best ,
Swapnil A Chaudhari
On Wed, 02 Dec 2009 19:10:49 +0530 wrote
>Thanks for the responses on how to match to points, however they raised a second problem which might be a bug in qgis or at least need a work around. That is, when I tried to find 'point sampling tool' it was not there and when I tried to install it the repository was unavailable and when I tried a manual download and install it would not work, see some details of correspondence about this below.
-----Original Message-----
Sent: 02 December 2009 12:52
To: M.E.Dodd
Subject: Re: [Qgis-user] DEM matching to points
On Wed, 2 Dec 2009 12:47:38 +0000
M.E.Dodd  wrote:
> Second reply, I wonder if it is something to do with proxies or something
> when its trying to connect
yes, or maybe windows? Best you test/ask for proxies and ask again on the ml,
because I use qgis 1.3 on linux so probably cannot not reproduce.
sorry
Otto
> From: Otto Dassau [mailto:otto.dassau at gmx.de]
> Sent: 02 December 2009 12:02
> To: M.E.Dodd
> Hi,
> in the fetch python plugins dialog, have you clicked on add 3rd party
> repositories in the repository tab?
> Otto
> On Wed, 2 Dec 2009 11:59:45 +0000
> M.E.Dodd  wrote:
> > Thanks, I'd tried that but could not see it on the list there either, I
> also noticed that it said that the official qgis repository was not
available
> and don't have any 3rd party repositories. Is there something else I am
> doing wrong?
> > Sent: 02 December 2009 10:08
> > To: M.E.Dodd
> > Cc: 'Marco Lechner - FOSSGIS e.V.'; qgis-user at lists.osgeo.org
> > Hi,
> > it is a python plugin. You have to download it with the "Python Plugin
> > Manager" Plugin (called Fetch Pytho Plugins) and then activate it inside
> the
> > "Plugin Manager" Plugin (called Manage Plugins ...) in the Plugins menu.
> > (looks more complicate as it is :))
> > Otto
> > On Wed, 2 Dec 2009 10:01:28 +0000
> > M.E.Dodd  wrote:
> > > Where is 'point sampling tool' as its not listed in the plug ins. I am
> > > using qgis 1.3 mimas on windowsxp.
> > > From: qgis-user-bounces at lists.osgeo.org
> > [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Marco Lechner -
> > FOSSGIS e.V.
> > > Sent: 01 December 2009 18:44
> > > To: qgis-user at lists.osgeo.org
> > > oh, great didn't know that one yet - all those new plugins - i think
i'm
> > > losing track.
> > > Marco
> > > Otto Dassau schrieb:
> > > > Hi,
> > > > there is also a python plugin called "point sampling tool" from Borys
> > > > Jurgiel. Maybe it is helpful as well.
> > > > Regards,
> > > > Otto
> > > > Am Tue, 01 Dec 2009 19:05:17 +0100
> > > > schrieb "Marco Lechner - FOSSGIS e.V." :
> > > >> by using the grass toolbox:
> > > >> import the DEM and the points into a grass database and use
v.to.rast
> > > >> Marco
> > > >> M.E.Dodd schrieb:
> > > >>> I have the GTOPO30 digital elevation model as a georeferenced
> > > >>> raster in qgis and a file of lat long coordinates I want to get the
> > > >>> elevation of, how do I do it? The points plot out fine over the
> > > >>> DEM, they are clearly matched up correctly but how to get the value
> > > >>> of the height out of the raster image and put it into the points
> > > >>> table. Thanks Mike
> > > >>> The Open University is incorporated by Royal Charter (RC 000391),
> > > >>> an exempt charity in England & Wales and a charity registered in
> > > >>> Scotland (SC 038302).
> > > >>> _______________________________________________ Qgis-user mailing
> > > >>> list Qgis-user at lists.osgeo.org
> > > >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > > Qgis-user mailing list
> > > FOSSGIS e.V.
> > > die unabhängige Hilfe bei freier GIS-Software und freien Geodaten
> > > www.fossgis.de
> > > The Open University is incorporated by Royal Charter (RC 000391), an
> exempt
> > charity in England & Wales and a charity registered in Scotland (SC
> 038302).
exempt
038302).
> The Open University is incorporated by Royal Charter (RC 000391), an exempt
charity in England & Wales and a charity registered in Scotland (SC 038302).
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091203/9a677a67/attachment.html>
