[Qgis-user] Problem with SDA4PP/Linked Statistical Display
Anne Ghisla
a.ghisla at gmail.com
Wed Dec 9 04:24:49 PST 2009
On Wed, 2009-12-09 at 04:17 -0800, Volkan Kepoglu wrote:
> updated with ver. 0.142, could you try that if it is fixed?
> 1. added loading of rJava package function
> 2. changed the style of loading of iplot package: first checks the
> package installed or not
> and then loads the package but skips to control the package whether it
> is loaded or not,
> because, most probably, i think that there is a bug for iplots
> package. even it is loaded, sometimes do not return true.
> for this reason, i prefered not to control the library whether loaded
> or not.
Hi Volkan, list,
sounds like the ade4 load failure for HomeRange_plugin
http://sourceforge.net/tracker/?func=detail&aid=2830501&group_id=48422&atid=453021
does the require(iplots) work on R?
if so, feel free to reopen the ticket on rpy2 trac.
HTH,
Anne
> On Tue, Dec 8, 2009 at 9:30 PM, Agustin Lobo [via OSGeo.org] <[hidden
> email]> wrote:
> Dear Volkan,
> Thanks for SDA4PP.
> When I try to run the Linked Statistical Display in SDA4PP
> (0.141) (R 2.10)
> (QGIS 1.3.0 from ubuntu jaunty binaries) I get the following
> error
> despite having the package rJava installed (also: note that
> rJava is
> not listed among the dependencies):
> Traceback (most recent call last):
> File "/home/alobo/.qgis//python/plugins/SDA4PP/sda4pp.py",
> line 163, in
> doIplotTool
> d = iplot.IplotTool(self.iface)
> File "/home/alobo/.qgis//python/plugins/SDA4PP/iplot.py",
> line 64, in __init__
> self.readInputFile()
> line 357, in
> readInputFile
> errorChecking = sda4ppLoadRpackage.readLib("iplot")
> File
> "/home/alobo/.qgis//python/plugins/SDA4PP/sda4ppLoadRpackage.py", line
> 57, in readLib
> result += loadIplot(r)
> File
> 137, in loadIplot
> if (r.require("iplots")[0]):
> File
> "/usr/local/lib/python2.6/dist-packages/rpy2/robjects/__init__.py", line
> 422, in __call__
> res = super(RFunction, self).__call__(*new_args,
> **new_kwargs)
> RRuntimeError: Error: package 'rJava' could not be loaded
> Thanks,
> Agus
> Qgis-user mailing list
> [hidden email]
> Regards,
> Volkan Osman Kepoglu
> PhD Candidate
> GGIT Department in METU,
> http:/ggit.metu.edu.tr
> ______________________________________________________________________
> View this message in context: Re: [Qgis-user] Problem with
> Sent from the qgis-user mailing list archive at Nabble.com.
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091209/565415d5/attachment.sig>
