[Qgis-user] Problem with SDA4PP/Linked Statistical Display
Agustin Lobo alobolistas at gmail.com
Tue Dec 15 01:20:43 PST 2009
This might be a clue:
require(iplots) does not work from within the manageR console
(Carson?):
 > require(iplots)
Error: package 'rJava' could not be loaded
while it works from a normal R console
(ubuntu 9.04, R. 2.10)
Agus
Volkan Kepoglu wrote:
> I assumed that the problem is related with pywin32 but your OS is
> ubuntu, so the problem should be related with either rpy2 or iplot
> package in R or with java.
> actually, i do not know the solution.
> regards,
> volkan.
> On Sun, Dec 13, 2009 at 12:44 PM, Agustin Lobo <alobolistas at gmail.com
> <mailto:alobolistas at gmail.com>> wrote:
>     But I still get the error on ubuntu 9.04 despite having
>     rJava available in R (2.10):
>     Traceback (most recent call last):
>      File "/home/alobo/.qgis//python/plugins/SDA4PP/sda4pp.py", line
>     163, in doIplotTool
>        d = iplot.IplotTool(self.iface)
>      File "/home/alobo/.qgis//python/plugins/SDA4PP/iplot.py", line 64,
>     in __init__
>        self.readInputFile()
>      File "/home/alobo/.qgis//python/plugins/SDA4PP/iplot.py", line 357,
>     in readInputFile
>        errorChecking = sda4ppLoadRpackage.readLib("iplot")
>      File
>     "/home/alobo/.qgis//python/plugins/SDA4PP/sda4ppLoadRpackage.py",
>     line 58, in readLib
>        result += loadIplot(r)
>      File
>     line 143, in loadIplot
>        r.require("iplots")
>      File
>     "/usr/local/lib/python2.6/dist-packages/rpy2/robjects/__init__.py",
>     line 422, in __call__
>        res = super(RFunction, self).__call__(*new_args, **new_kwargs)
>     RRuntimeError: Error: package 'rJava' could not be loaded
>     Agus
>         finally, cleaning the upgrade and the glitches in the plugin gui
>         under linux is completed - i think.
>         please, update the plugin to rev. 0,151.
>         regards,
>         volkan.
>         On Wed, Dec 9, 2009 at 11:52 PM, Paolo Cavallini
>         <cavallini at faunalia.it <mailto:cavallini at faunalia.it>
>         <mailto:cavallini at faunalia.it <mailto:cavallini at faunalia.it>>>
>         wrote:
>            Please note: the upgrade seems not to be clean. I keep on
>         having the
>            plugin
>            marked as upgradeable, even after the upgrade. This has already
>            happened in
>            the past.
>            Thanks Volkan!
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
