[Qgis-user] Problem with SDA4PP/Linked Statistical Display
Carson Farmer
carson.farmer at gmail.com
Wed Dec 16 08:02:13 PST 2009
This might be because Rpy2 doesn't seem to look in all the same places
that R does... what about specifying the library location when using
library... though this isn't a solution for the plugin, it might help to
narrow down the problem...
?library
Carson
> This might be a clue:
> require(iplots) does not work from within the manageR console
> (Carson?):
> > require(iplots)
> Error: package 'rJava' could not be loaded
> while it works from a normal R console
> (ubuntu 9.04, R. 2.10)
> Agus
> Volkan Kepoglu wrote:
>> I assumed that the problem is related with pywin32 but your OS is
>> ubuntu, so the problem should be related with either rpy2 or iplot
>> package in R or with java.
>> actually, i do not know the solution.
>> regards,
>> volkan.
>> On Sun, Dec 13, 2009 at 12:44 PM, Agustin Lobo <alobolistas at gmail.com
>> <mailto:alobolistas at gmail.com>> wrote:
>> But I still get the error on ubuntu 9.04 despite having
>> rJava available in R (2.10):
>> Traceback (most recent call last):
>> File "/home/alobo/.qgis//python/plugins/SDA4PP/sda4pp.py", line
>> 163, in doIplotTool
>> d = iplot.IplotTool(self.iface)
>> File "/home/alobo/.qgis//python/plugins/SDA4PP/iplot.py", line 64,
>> in __init__
>> self.readInputFile()
>> File "/home/alobo/.qgis//python/plugins/SDA4PP/iplot.py", line 357,
>> in readInputFile
>> errorChecking = sda4ppLoadRpackage.readLib("iplot")
>> File
>> "/home/alobo/.qgis//python/plugins/SDA4PP/sda4ppLoadRpackage.py",
>> line 58, in readLib
>> result += loadIplot(r)
>> File
>> line 143, in loadIplot
>> r.require("iplots")
>> File
>> "/usr/local/lib/python2.6/dist-packages/rpy2/robjects/__init__.py",
>> line 422, in __call__
>> res = super(RFunction, self).__call__(*new_args, **new_kwargs)
>> RRuntimeError: Error: package 'rJava' could not be loaded
>> Agus
>> finally, cleaning the upgrade and the glitches in the plugin gui
>> under linux is completed - i think.
>> please, update the plugin to rev. 0,151.
>> regards,
>> volkan.
>> On Wed, Dec 9, 2009 at 11:52 PM, Paolo Cavallini
>> <cavallini at faunalia.it <mailto:cavallini at faunalia.it>
>> <mailto:cavallini at faunalia.it <mailto:cavallini at faunalia.it>>>
>> wrote:
>> Please note: the upgrade seems not to be clean. I keep on
>> having the
>> plugin
>> marked as upgradeable, even after the upgrade. This has
>> already
>> happened in
>> the past.
>> Thanks Volkan!
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
National University of Ireland, Maynooth,
Email: Carson.Farmer at gmail.com
Web: http://www.carsonfarmer.com/
http://www.ftools.ca/
