[Qgis-user] Clip from Rectangle defined by Coordinates
murali.krishna.gurram
murali.krishna.gurram at gmail.com
Mon Dec 21 01:56:50 PST 2009
Dear Mr. Andreas,
In fact I have been searching for the GUI with same functionality "Custom
BoundingBox" for the last couple of days as it is very important for my
work.
QGIS has a built-in tool available for this in TOOLS - RESEARCH TOOLS -
VECTOR GRID
But, I found it is not at all working normally (when you start the process
it will continuosly run without no end). I think there is a bug with this
tool which needs to be fixed immediately (and lot many with other options).
It is a very common problem everyone used to face regularly, but still there
is no solution for this so far.
I found one 'libspatialindex-1.4.0-win32' but still unable to use the same
plugin with QGIS 1.3.0.
Please let me know if you arrived at any solution for the customized
boundingbox problem.
Regards,
Murali krishna Gurram
Andreas Neumann-4 wrote:
> Hi,
> This is perhaps more a question towards Carson and others dealing with
> fTools.
> Regarding clipping: one common scenario is that one wants to clip a
> rectangular area based on corner coordinates, e.g. lower/left and
> upper/right corner.
> Currently, one would have to generate a file or table physically
> containing the clipping rectangle. For this scenario it would be more
> convenient if the clipping rectangle could be defined by coordinates,
> without having to generate a dataset first.
> Do you think this could be implemented in fTools for convenience? Perhaps
> one could use the memory provider for this purpose and add some GUI for
> entering coordinates for the corners of the rectangle.
> What do you think? Would this be of general interest?
> Andreas
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
> Qgis-user mailing list
View this message in context: http://n2.nabble.com/Clip-from-Rectangle-defined-by-Coordinates-tp4125730p4197241.html
Sent from the qgis-user mailing list archive at Nabble.com.
