[Qgis-user] manipulating shapefiles
Carson Farmer
carson.farmer at gmail.com
Wed Dec 23 09:54:17 PST 2009
If your shapefiles are actually projected to srid 4326, and have just
been assigned an srid of -1, then you can use the define projection
tool in the tools menu (note, there is currently a bug which outputs
the name of the resulting .prj file wrong, so please remember to go
into the directory with the file and rename it). If it`s something
else, you can right click the layer, and use save as shapefile, which
will ask which output crs to use...
Hope that helps,
Carson
On Wed, Dec 23, 2009 at 5:05 AM, sunny74 <sb.ray at hotmail.com> wrote:
> Hi,
> I have got several shapefiles from which I am able to display map using
> mapserver.
> But the problem is that it has a srid value of -1 i.e no projection.
> As a result of this several functionalities which uses geometry are not
> working.
> I think the default srid value is 4326.Pls confirm.
> I want to convert the srid value from -1 to 4326.
> How can I do this using QGIS?
> I know this is possible using GEOMEDIA Web 6.0.
> If anybody has any idea or tutorial regarding .shp manipulation using
> Geomedia pls send it across.
> Thanks for ur replies.
> sunny74
> View this message in context: http://n2.nabble.com/manipulating-shapefiles-tp4207296p4207296.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
Carson J. Q. Farmer
National Centre for Geocomputation
National University of Ireland, Maynooth,
Maynooth, Co. Kildare, Ireland.
http://www.carsonfarmer.com/
