[Qgis-user] manipulating shapefiles
sunny74 sb.ray at hotmail.com
Thu Dec 24 04:05:13 PST 2009
Hi Carson,
There is no define projection tool in the tools menu.
Which version of QGIS r u using? I am using MIMAS ver 1.3.0
Regarding the second method if I right click and click "save as shapefile"
it only asks the place to save
and not CRS.
Pls let me know if u have a solution to this.
Thanks for your reply.
sunny.
Carson Farmer wrote:
> If your shapefiles are actually projected to srid 4326, and have just
> been assigned an srid of -1, then you can use the define projection
> tool in the tools menu (note, there is currently a bug which outputs
> the name of the resulting .prj file wrong, so please remember to go
> into the directory with the file and rename it). If it`s something
> else, you can right click the layer, and use save as shapefile, which
> will ask which output crs to use...
> Hope that helps,
> Carson
> On Wed, Dec 23, 2009 at 5:05 AM, sunny74 <sb.ray at hotmail.com> wrote:
>> Hi,
>> I have got several shapefiles from which I am able to display map using
>> mapserver.
>> But the problem is that it has a srid value of -1 i.e no projection.
>> As a result of this several functionalities which uses geometry are not
>> working.
>> I think the default srid value is 4326.Pls confirm.
>> I want to convert the srid value from -1 to 4326.
>> How can I do this using QGIS?
>> I know this is possible using GEOMEDIA Web 6.0.
>> If anybody has any idea or tutorial regarding .shp manipulation using
>> Geomedia pls send it across.
>> Thanks for ur replies.
>> sunny74
>> View this message in context:
>> http://n2.nabble.com/manipulating-shapefiles-tp4207296p4207296.html
>> Sent from the qgis-user mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Carson J. Q. Farmer
> National Centre for Geocomputation
> National University of Ireland, Maynooth,
> Maynooth, Co. Kildare, Ireland.
> http://www.carsonfarmer.com/
View this message in context: http://n2.nabble.com/manipulating-shapefiles-tp4207296p4212999.html
