[Qgis-user] Alternative schemas for postgis geometry_columns?
Mike Toews mwtoews at sfu.ca
Mon Dec 28 09:24:27 PST 2009
There are two things I can think of, both of which I haven't tested.
1. Modify your database search path to include the postgis schema by
default:
ALTER DATABASE mydatabase SET search_path=public,postgis;
or
2. Create views to the two tables in the public schema (assuming you
kept this as from the default):
CREATE OR REPLACE VIEW spatial_ref_sys AS SELECT * FROM
postgis.geometry_columns;
-Mike
FW wrote:
> In my postgis installations, I like to keep my postgis junk in its own
> schema (aptly named "postgis"), and then to set postgis to the last
> element in the search path. This way you can drop the entire thing by
> dropping the schema, you can search for functions in postgis.*, etc.
> However, when I connect QGIS to my DB, it can't find my
> geometry_columns, spatial_ref_sys, or the fact that I have a geometry
> type.  These are all quite visible from the psql prompt using \dT and
> the like
> Is there a way to have QGIS look in the schema postgis for this?
> I am running 1.3.0 on freebsd, with both spatialite and postgis supported.
> Tx!
> Qgis-user mailing list
