Error loading HomeRange plugin on Mac OSX[was: Re: [Qgis-user] Fwd: Hello, ]
Carson Farmer
carson.farmer at gmail.com
Thu Jul 16 07:56:28 PDT 2009
Hi all,
> With all this, I was able to install and enable the HomeRange plugin
> in Qgis 1.1.0 once - it loaded and showed up in the plugins menu.
> After restarting Qgis, I got an error loading HomeRange:
> Traceback (most recent call last):
> File "", line 2, in
> File
> "/Users/kyngchaos/.qgis//python/plugins/HomeRange_plugin/__init__.py",
> line 32, in
> from HRplugin_main import HRPlugin
> File
> "/Users/kyngchaos/.qgis//python/plugins/HomeRange_plugin/HRplugin_main.py",
> line 40, in
> from HRplugin_dialog import Dialog
> File
> "/Users/kyngchaos/.qgis//python/plugins/HomeRange_plugin/HRplugin_dialog.py",
> line 44, in
> from HRplugin_algorithm import *
> File
> "/Users/kyngchaos/.qgis//python/plugins/HomeRange_plugin/HRplugin_algorithm.py",
> line 46, in
> import rpy2.robjects as robjects
> File "/Library/Python/2.5/site-packages/rpy2/robjects/__init__.py",
> line 12, in
> import rpy2.rinterface as rinterface
> File
> "/Library/Python/2.5/site-packages/rpy2/rinterface/__init__.py", line
> 6, in
> R_HOME = os.popen("R RHOME").readlines()
> IOError: [Errno 4] Interrupted system call
This appears to be a general PyQt problem with 'popen', and appears to
be especially problematic for macs. I think what's happening is that
PyQt is interrupting the (slower?) os.popen command, making it
impossible for rpy2 to find RHOME. This is why things work when entered
into a normal console...
I have yet to find a way to effectively fix it, but I'm going to look
into it further tonight, so hopefully I'll have a solution in the next
few days. It actually doesn't happen all the time, which makes it
slightly harder to pin down. ...
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
Email: Carson.Farmer at gmail.com
Web: http://www.carsonfarmer.com/
http://www.ftools.ca/
