[Qgis-user] Ctrl ++
Agustin Lobo
alobolistas at gmail.com
Fri Jul 31 04:03:13 PDT 2009
Based on intuition
I think that Ctr++ and Ctrl+- are the way to go for the zoom (as
described in
the manual!), they should just work.
Anyway, if we are going to be able of customizing all this, no problem
Thanks, at least I can zoom with the keyboard now!
One last thought: at least as an option, should not zooming re-center
the image so that the
current position defined by the pointer become the new center?
Agus
Otto Dassau wrote:
> Hi,
> On Fri, 31 Jul 2009 11:19:45 +0200
> Agustin Lobo <alobolistas at gmail.com> wrote:
>> When I use Ctrl++ (or Ctrl+-) in qgis 1.1.0 unstable for ubuntu
>> I just get the sign changed to + (or -), but not actual zoom in
>> or out. Is this a bug or is it intentional? If it's intentional,
>> then the user has to click with the mouse, which is
>> against the essence of a keyboard shortcut (and very
>> inconvenient in the field).
> Just tested on debian: The short cuts for zooming and panning with the keyboard
> works like this:
> Place the mouse cursor inside the map area (or activate the map area with the
> tab key) then use the arrow keys for panning and the up and down keys for
> zooming.
> The combination (mouse + keys) you described works also, of course.
> Regards,
> Otto
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
