[Qgis-user] Ctrl ++
Otto Dassau otto.dassau at gmx.de
Fri Jul 31 04:23:24 PDT 2009
On Fri, 31 Jul 2009 13:03:13 +0200
Agustin Lobo <alobolistas at gmail.com> wrote:
> Based on intuition
> I think that Ctr++ and Ctrl+- are the way to go for the zoom (as
> described in
> the manual!), they should just work.
yes, it is described that way in the manual and it is also defined that way in
the "settings" => "configure shortcuts" of trunk. I guess the developer, who
added that short cut will be able to answer your question - I am not.
> Anyway, if we are going to be able of customizing all this, no problem
> Thanks, at least I can zoom with the keyboard now!
yes, but there should be a default short key setting for this.
> One last thought: at least as an option, should not zooming re-center
> the image so that the
> current position defined by the pointer become the new center?
I think that's how it works. You can somewhere and the new center is also the
zooming center, or do I missunderstand?
 Otto
> Agus
> Otto Dassau wrote:
> > Hi,
> > On Fri, 31 Jul 2009 11:19:45 +0200
> >> When I use Ctrl++ (or Ctrl+-) in qgis 1.1.0 unstable for ubuntu
> >> I just get the sign changed to + (or -), but not actual zoom in
> >> or out. Is this a bug or is it intentional? If it's intentional,
> >> then the user has to click with the mouse, which is
> >> against the essence of a keyboard shortcut (and very
> >> inconvenient in the field).
> > Just tested on debian: The short cuts for zooming and panning with the
keyboard
> > works like this:
> > Place the mouse cursor inside the map area (or activate the map area with
the
> > tab key) then use the arrow keys for panning and the up and down keys for
> > zooming.
> > The combination (mouse + keys) you described works also, of course.
> > Regards,
> >  Otto
> >> Thanks
> >> Agus
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
