[Qgis-user] Snapping, Pyramids
Carlos Dávila cdavilam at jemila.jazztel.es
Wed Mar 4 07:05:00 PST 2009
Matej escribió:
> Hi,
> is there an option of "snapping" vertexes / lines to a vertex / line
> that is in another layer? We have some lines that we would like to
> draw on / put vertextes on lines and this option would save a lot of time.
You can customize snapping behaviour in the Project properties dialog,
General tab, at the bottom. You can select any layer to snap to
vertex/segments/both.
> Another thing is the problem with using Pyramids on raster files
> (GeoTIFF). We tried to create pyramids on Windows XP, Server 2008 on
> more computers and when trying to build pyramids we always get an
> error: "Write access denied. Adjust the file permissions and try
> again." and the directory should be writable by user which QGIS is
> running as. Is there any solution for this?
> Thanks,
> Matej
> matej at matnet.net <mailto:matej at matnet.net>
> Qgis-user mailing list
Por favor, no me envíe documentos con extensiones .doc, .docx, .xls, .xlsx, .ppt, .pptx, .mdb, mdbx
Instale OpenOffice desde http://es.openoffice.org/programa/index.html
OpenOffice es libre: se puede copiar, modificar y redistribuir libremente.
OpenOffice es gratis.
El uso de OpenOffice es totalmente legal.
OpenOffice funciona mejor que otros paquetes de oficina.
OpenOffice está en continuo desarrollo y no tendrá que pagar por las nuevas versiones.
