[Qgis-user] map collars
MS mseibel at gmail.com
Wed Mar 18 13:07:18 PDT 2009
I realize this goes into other software on a qgis list, but I wonder
with GDAL or GRASS one can accomplish this.
It is really a raster clip that would work well, especially if the
next step is mosaic'ing the rasters.  Are these quad maps?
Mark
On Mar 18, 2009, at 3:28 PM, "John C. Tull" <john.tull at wildnevada.org>
wrote:
> Although, this approach can be problematic if white is important for
> properly displaying the map information. E.g., USGS topographic maps
> use a white background for the map and a white collar. My solution
> was to hand select the collar in Gimp, make it a unique color
> (magenta or something), then apply the transparency to that color.
> This is not fun if you have many maps to work with.
> John
> On Mar 18, 2009, at 4:17 AM, Paolo Cavallini wrote:
>> Chris h ha scritto:
>>> No apology necessary. Map collars are the white borders around
>>> maps that are
>>> typically distributed from governmental sources in raster format.
>>> In order to
>>> stitch or glue charts together you need to remove the collars.
>>> (white area)
>> Oh, that can be easy: for displaying purposes, just set the white
>> value
>> to null, in the raster properties dialogue. If you want to
>> permanently
>> set the white to NULL, you can use gdal for this.
>> All the best.
>> Paolo Cavallini: http://www.faunalia.it/pc
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
